I have a Vaio VGN FE28H. Since last saturday I cannot start windows any more. When I turn on the computer, the Vaio logo is loaded, then I have the windows loading screen, but at the moment windows has to open, the computer restarts, and the same cyclus begins again.
As I had some problems with my antivirus, I do not exclude that I caught a virus and that's the reason why windows won't start anymore.
I think the only way (or is there another one?) to repair this is to make a recovery of my computer. But I did'nt made the recovery media kit when computer was still working good. Can I find this somewhere on the net, or is there another way to solve my problem?
Thank you
Hi gmossoux,
start your Vaio and when you see the Vaio logo press the F10 key repeatedly, this should start the recovery utility..
Thanks I will try
You're welcome..
Thank you it worked.
that's good news..
