I ask how to find again "Power options" .
Even the turn dow and long turn dow disappears.
Icons are visibles, but clicking on is inoperative.
I can reload "Power Panel", from CD install, but it can't work (see the joins parts).
What is the solution ? Thank you.
!http://|src=http://|border=0!
Sorry but I can't read blue on blue
Select the text by dragging Fee-Lo.
I'm sorry your images appear to have the wrong URL, they don't show up. Can you post them with the correct URL?
I just added this for you as a quote Kee-lo , I have no idea other than this,more so can read the Text .
I write again my question, and try to show my display copies:
Somes months ago, I lost "Power options": they were no actives, even the program is present, and, for example, the screen is always bright (since, I solve this problem, utilizing blank turn down display).
Since somes days, even the turn down and long turn down disappears.
joins parts).
So, I think that, perhaps, some users had this problem and had solved it...?
If so, thank you to help me.
My images (I try !)
[img]http://[C:\Documents and Settings\Richard TAITOT\Bureau\Sony OP.jpg]xxx][C:\documents and settings\richard TAITOT\Bureau\SonyPP.jpg]:smileygrin:
I don't succeed in doing !:smileysad:
Richard , I believe you need to upload the Image to the Internet , add your image to a place you have control of on the internet ,
They would then be easily added by the normal way , use the URL of the Image , hope it might help .
Try using Lycos Webspace to upload pictures.
www.tripod.lycos.co.uk
Oops. Sorry if I'm stepping on toes but I heartily recommend www.photobucket.com for your picture hosting needs.
