Hi- Does anyone know how to avoid "power management error" when burning DVD? It only occurs while burning DVD+R and not other kind.
Thanx
Make sure you are running in performance mode and have it hooked up via AC
Otherwise try different disks, sometimes this can be due to the layering not being right for the burner to burn data on.
What is "performance mode"? Otherwise I was plugged to AC.
I've also tried to find an updated driver for this burner without any success... Is it possible that there is a problem with the hardware itself?I did a mistake: it's a "power CALIBRATION error", but it doesn't help me so much...
Ty1
This usually happens when you use media that the drive cannot write to well.
Best trying TDK.
After calling the VAIO hotline, I've uninstalled and reinstalled the driver of the DVD recorder and now... it works fine, even with the low prices DVD+R that didn't work before !
Thanks Kee-lo for answering.
Ty1
Great
