Got a VAIO Tr1 in September last year. tried a plastic Cover for carrying around ( from a paper shop A4+) , but In the end I bought the carrying pouch that was offered for the Vaio Tr1 back then (November I think) . Igot it 2 weeks later and found that it is the perfect solution for my needs:
perfect fit, no extra space for things I wouldnt like to carry in my notebook case anyway.Small Frm factor , only one Centimeter bigger than my Tr1
great look :
It's silver with the VAIO Logo on it
It gives the Protection I need to carry it around in my bag everyday
Only problem is: Ithink it isn't offered by SONY anymore. Maybe you can find it on E-Bay.
I've just bought the ultra fit tr2 and am very impressed with it. It is so very light and portable, however I don't want to take it anywhere in danger of scratching/damaging it. Trying to find a case but being so small it tends to rattle around in most cases. Are there any companies that make covers this small?
www.thepouch.co.uk
Cheers, thats great.
Just checked them out. Looking for something a little more chic. Tried phoning local sony centre. They do an officail one. Wanted to charge £50 for it FIFTY POUNDS! I don't understand. I have found the same case on the net for £38 from other sources. You'd have thought the cheapest place to get sony goods from would be a sony store. How wrong I was.
The Pouch isn't really bad imho.
You could always try the CT5K Vaio case. There is only enough room for the machine and it isn't cheap, but it does look good.
It took 6 weeks wait for Sony in Manchester to get one for me, but it was worth it.
