hi have a pvc w2 but i wat 2 put ny home cinema on it how do i do it i have tryed the phono leads but that don`t work....
So you want it to display on your home cinema?
do you mean you want your home cinema surround kit hooking up to it? if thats yes then you cannot thru the phonos as they are INPUT only... hopefully your dolby kit has an optical connection, if so, all you need is an optical lead to connect the 2... digital surround, LOVELY..
make sure in the pcs volume properties ac3 and pcm spdif are checked, its under advanced.....
