I've got a PCV 502 Desktop, but I can't find any info regarding the make/model of the Motherboard...does anyone know?
Unless someone knows better:smileygrin: , I have never seen references to makes and models of motherboards.
I am sure if its broken Sony will fix it, but they do not tend to be generic motherboards and I assume Sony either manufacture the boards themselves or have them made to their own Sony design.
If you wanted to upgrade the CPU, the chipset should be the key to determining max processor speed.
I am not even sure a generic ATX motherboard would fit and then their would be problems with hooking up all the lights etc as no doubt the Sony plug for all this will be in one block.
William
They are made by ASUS but we are not told what make/model or anything, and ASUS can't help either.
Thanks Kee-Lo, it is reassuring to know that they are manufactured by a well known motherboard manufacturer.
William
Thanks for the info guys...I find it a bit strange that we don't know what the model is...I mean how do you update the board, know what processor you can add...etc
William
VAIO PCs aint really made for upgrades - they're made for people who want a desktop and won't be updating the hardwrae often or at all. If you want to do that sort of thing build it yourself.
Nothing is cheap but I have never seen computers cheaper (comparitively).
If its old and you can pick up a faster processor cheap on Ebay to give your computer a bit more life - Fine.
I personally see little point in major upgrades with the prices of base units what they are now.
To me the only exotic bits are the very leading edge CPU's and graphics cards which are always going to cost an arm & a leg.
And believe it or not I used to be the world leader in PC upgrades. I must have wasted a bloody fortune just to play the latest games.
William
Some graphics cards cost > £500 and CPUs on day one cost around £400!
