Hi all
Am new to this forum but hopefully you guys might know the answer! I purchased a PCG-8L2M model 20 months ago. The laptop gets extremely hot then shuts down sometimes after 20 minutes sometimes 30 minutes.
I have virus scanned with zone labs but this is -ive?
Any clues would be very much appreciate:smileyconfused:
hi again, remember i spoke to you about the heat under my lap top, i checked out the link to mobilemeter, its really good i been using it my cpu is 56 oC is that good?
Is that a Intel Centrino CPU or a Intel Pentium4?
If it a Centrino, then I think it's Ok, but for a Pentium4 it's a bit high.(by normal working, by 100% CPU usage I had measured 73degrees on my VAIO)72 degrees are critical for a Pentium4 and approx 100degrees for the Centrino.
It's good, but you should keep an eye on it.
its a centrino m processor the max i messured was 60 oC but that was the cpu at 100% its running cooler now since i been using the laptop on a work top, before i was using it on the carpet which was making it heat under, now i got a piece of glass
how about get a small desktop fan and blow it away?.. :smileygrin:
Many thanks for the advice chaps:smileygrin:
I have given the laptop a gentle hoover. The temp is currently 76C and the HDD #0 is 44C (Sorry guys, but what is the first temp reading? I assume HDD is Hard Disk Drive?!?) after approx 45 minutes of running on a worktop.
Any views?:smileytongue:
PS you can probably tell I am a complete IT novice. Accounting/Tax/Investment and performance cars are my skills should any body require!!
Yep, HDD is the harddisk, but 45 degrees is a little bit warm. 76degrees maybe OK for a Centrino CPU but not for Pentium 4 (you have a Centrino)
I have read that the max. stable temperature for a Centrino is approx 100 degrees. So, I think your laptop could be very hot if you stress the CPU.
It's a touch on the high side.
You and TellingD have something in common then
