Hi all
Am new to this forum but hopefully you guys might know the answer! I purchased a PCG-8L2M model 20 months ago. The laptop gets extremely hot then shuts down sometimes after 20 minutes sometimes 30 minutes.
I have virus scanned with zone labs but this is -ive?
Any clues would be very much appreciate:smileyconfused:
Hi there.
Welcome to the forum:smileygrin:
Quite often it's somethng as simple as dust build up on your fans. After 20 months I should think there may be quite a bit by now.
Ah this time of the year, weather gets a bit hot, and VAIOs overheat.... guess thats the price for near silent computing.
Try using a hoover to clean your fans, make sure you have the fans on full too.
Yeah, the question here is :
Are the fans powerfull enough to cool down, a overheated CPU? The fans in my old VAIO can do this.
The hoover was good idea Kee-Lo. Normally the CPU in my VAIO has approx 45-47 degrees. After the hoover action, my VAIO works with 41-42 degrees.
What temperature is your laptop reaching?
You can get accurate temperature mesurement using this.
Hope a cleanup sorts it out.
Good question Seb, and yes I think you're right, but then customers would complain the fans are too loud, catch 22 again....
truuuuueeee:smileyrolling_eyes:
whoa...just checked that program mobile meter to check my laptop stats, its hitting around 60 degrees! any help on coolin it down?
i've tried cleanin out my laptop...
A hoover could help................
................(or compressed air:smileyrolling_eyes:)
LOL we get it now Seb, you hate compressed air.
