I have Vaio VGN-AR51J for several years, with Windows Vista. Now I decided to upgrade my current OS to 64 bit Windows 7 Enterprice.
At the moment I`m looking for Nvidia Geforce 8400M GT graphic card and memory card Memory stick reader/writer drivers(Magic gate) drivers.
Thank you!
No guarantees as Windows 7 64-bit is not supported by Sony on your model - but I would try the following drivers: -
nVidia Graphics Driver 8.15.11.8540_0910130 64-bit from the Windows 7 downloads for the VGN-AW11Z from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW11Z_B&os=10
I know the AW11Z has the 9600M chip but I would expect it to install.
The memory card drivers are not OS dependent so you just need a 64-bit Texas Instruments Memory Card Driver. Sony have made someunofficial Vista 64-bit drivers available. I think you need Download: EP0000140007.zip from here: -
http://www.vaio-link.com/os/vista/64bit/
to>> blencogo.
memory car driver not working from sony support site, even is not a driver.
I downloaded drivers for texas instrument pcixx12 from : http://forum.vista-driver.org/index.php?showtopic=285&pid=1871&st=0&#entry1871 , and now my memory card reader working properly.
What else drivers I can try for 8400m GT?
Hi Zilrast,
What is still not working?
Just found 8400m GT drivers from Vista 64 and instaled. Working! Happy now
There is link for vista 64bit drivers : http://dls.update.sony.net/pub/oth/64/EP0000146244.zip
Now left to find drivers for: DVD eject buton; mute; S1 and S2 butons; play,stop,pause ,etc butons.Any ideas where from I can get drivers for these butons?
Apart that, everything is working
You will need to find some 64-bit Sony Utilities to get these to work. I don't think these exist for your model so you may have to try them from another Vaio.
It sounds to me like you need: -
SFEP Driver
Sony Shared Library
Vaio Event Service
Good Luck!
Czy jest aktualizacja do NVIDIA geforce 8400M GT drivers for 64 bit Windows10 ?.
