Hi all!
I want to renew the Norton Internet Security that was installed in my VAIO when I bought it 3 mounth ago.
Do I need to renew with VAIO directly? or Do I need to contact with Norton support?
Thank you in advance,
David
Hi dave, you should have 9 months free left with Norton and when the time to renew arrives you will be invited by Norton Via a popup to renew your subscription. hope i been of help...
steve.
I think it's only 90 days you get free but as Nerm says you should get an invitation pop up a couple of weeks before the original one expires.:smileyhappy:
Oh, and welcome to the forum:smileygrin:
I remember it just has 90 days that you can update. To be honest, I do not like Norton, you have to set up a lot and slow. Why not try another one?
I suggest buying the boxed edition, so you can reinstall if anything goes wrong, and you get a full years support and updates
NAV
thank you to all.
I didn't replay before because I was out ...
Best regards,
David
