I have got everything up and ready but cannot get the media receiver to talk to the wireless network converter. When going thirught the registration of the 2 devices, my TV keeps coming up with "failed to register this device" I have the network set up for ad hoc. Can someone plese help me with this as i have been at this for a week now!:smileyconfused:
Yup JL in Aberdeen. If i cnnot get it set up this weekend i may well take you up on that offer. cheers
Would that be John Lewis Aberdeen by any chance? If it is i worked on your computer with Alex.
If you want i can drive round one night and help you set it up.
Graham
I cannot get this to work. If you are willing to help out i wuold appreciate it. Let me know if you can help set this up. i can be found at [email protected]
Thanks
Those new ones look good, but you're going to have to save your pennies DT
If you do house calls to Glasgow I'll put my order in for one of those new VAIO deaktops now :smileygrin:
Did you manage to fix the problem? Only I'm having the same sort of thing with mine. PCVRZ 504) Can't register the device. When I click on Start/IPrograms/Wireless Lan/Converter Utility Set up it tells me that it can't find the converter and asks me if I want to go to online help. I followed the instructions in the trouble shooting ie, turning off the firewall and disabling the network bridge etc but it stubbornly refuses to read anything.
Have you any idea what that corrupt file was that John Lewis repaired?
Would be interested to hear how you got on.
The error was something like a pnp sony network error. JL reset the system and all seemed well. i can get the media player to play files from the computer when the media receiver is hooked up to the ethernet port on the machine but still cannot get the system to work wireless. the problem you are having was the same as my initial one. Make sure the converter and wireless card are set up for an ad-hoc network rather than a wireless. when set up the converter will have a pink light rather than the red and will not flash. i did not find anything about that in the info pack though!!!
Do you mean UPnP?
Do you mean UPnP?
