x
olo
Visitor
Net-MD problems
The Net MD drive of my PCV-RX413N is playing only three songs of a record. After this it start to searching (without success) and switch off. It is impossible to reactivate the drive (only by rebooting the computer) :slight_frown:
Is it a Software or a Hardware problem? What can I do?
Thanks for help
Olo
2 REPLIES 2
EzDoezIt
Visitor
I don't know if :arrow: VAIO Link Solution 31643 is of any help, but it also talks about the magic number 3.
Also have a look at these :arrow: search results.
RobertStalker
Visitor
If it works for three songs, then it searches, means the software is searching for data that is no longer available either by deletion or corrupted data. I would certainly concentrate on the software.
