My Vaio VPCCW2S1E wont shut down. I have to force it by hitting the power button. I tried everything ( format, restoration from backup disks). Yet the problem renains. Any suggestion?
Thank you?
Hi irakliotis,
I've exactly the same problem. I cannot fix it either. Like watching paint dry but not as exciting. Just one more anoyance of that confounded VISTA flaming plague.
