I have a VGN-c1Z/B and have successfully enabled Bluetooth to find my iphone. However When it trys to connect it asks for a PIN number. I haven't given it one so where do I find it?
Thanks
Tony
Hi Tony,
I may be wrong but normally, if the code is not pre-set, then you can just type a 4 digit code to pair devices.
However I'm not sure if you can link an iPhone to a PC unless it's for internet tethering..
