Help!! I must be going mad with my VAIO pocket or there is a bug on the software. Can someone please confirm what I need to do to remove any songs selected for 'My Playlist' . You see List 1 has the same song selected several times, I know it sounds clumsy but the operating instructions read that by going into the advance menu in 'My Playlist' you are able to remove the tracks.
P.S : I have all the updated stuff S/S 3.3 and Firmwire 3.0
It seems that small things in life can drive you up the wall.
If you go into My Playlist, select the required list. Then using one of the centre 3 columns on the G-sense pad, hold down a button corresponding to the track you want to remove for 3 seconds. This will bring up the Advanced Operation Buttons. On the right hand side you will now see more options.
1. Close Adv Op Display
2.Move Song Up in List
3. Move Song Down in list
4. Remove all Songs
5.Remove Selected Song from List
You will then be asked "Are You sure".
Hope this helps!
Thanks Mr, I can know sleep at night.
