The DVD-ROM on my PCV-RZ221 doesn't appear anymore on My Computer and I can' t open it anymore! The DVD R/RW is still ok. Can anybody tell my how this come and how can I install my DVD ROM back?
Thanks.
Have you installed Sp2 lately?
Yes, i did! You arn't, I hope, suggesting that I have to thank Microsoft for this?!! This will certainly be the last time I buy a pc. My next one will be an Apple. That's for sure.
If this problem comes with SP2 what do you think I have to do?
Hmm, I have no idea if SP2 caused your problems, but if the DVD worked before then I suggest downloading all the latest downloads from Windows Update and on Vaio-Link.com
