The problem started when Microsoft SP2 was getting downloaded. Half way through, it got frizen!
I had to switch off the machine manually. When switched back on again everything had gone! All desktop icons,ncluding the "Start" button!
I took the laptop to PC World for repair. They said I have to use the System Recovery and Documentation Disk which I did. However when I put the disk in, nothing happens!
Has anyone had experience like this? I will be grateful for your advise.
Thanks
Sabi:smileyconfused:
Hi Sabi,
Sounds like it crashed during the installation process.
The best thing to do is press F2 when you see the VAIO Logo
Tell it to boot from CD
Insert the Recovery CD
save the settingd of the BIOS, this will restart the machine
The recovery process should be now running.
Follow on-screen instructions.
Hi Kee-lo
Thanks for your reply.
I am not a computer expert, but I did press all the "F's" on the keyboard! when nothing happened. Do you mean I should press F2 continuesly?
I also couldn't understand the meaning of "tell it to boot from CD"? or "Save the setting of the BIOS"?
Sorry, but I said I am no expert !!!
I cannot wait to have my Vaio back to normal
Thanks again
Sabi
Fire your machine up. When you see the Sony logo appear keep hiting the F2 key until you see a menu. On that menu will be the words " boot from cd". Click it then put your recovery disc in and wait a sec. You should then see another menu this time with an option that says "Save the setting of the BIOS. Click on that which will start the recovery process.
Good luck
(Sorry Kee-Lo if I've just repeated what you've just said but thought I'd "embelish" it a bit :smileygrin: )
Thanks TR, no problem....
Hi Twisted-Rizla;
Thank you for explaining the procedure clearly.
However when I switch on the laptop, I see the Window XP getting loaded, but then I get this message[ Explorer.EXE- Entry Point Not Found] underneath it says "The procedure entry point SHCreate ThreadRef could not be located in the dynamic link library SHWAPI.dII." when I press OK it goes to the desk top,with no desk top icons, not even the "Start" button, only the screen desktop picture.
I must mention that the only thing seems to work is "End Task Manager"! There is nothing in applications but when I click on performance there is 0% in CPU usage and 84.5MB in PF Usage What ever that means!!
I've pressed F2 with which I couldn't get anywhere. So how do you mean by "fire your machine up until you see Sony Logo" ?
At any stage when I put the recovery disk in, I see nothing . It is like the the machine is trying to do something but it cann't! I also tried the safe mode "F8" but the black screen comes up with no other modes to click on....!
I don't know what is really happening and why it's so difficult if not impossible to get back my Vaio to at least the manufacturers setting?
If it wasn't for flipping MS SP2 update, none of these would've happened.
Thanks again
Sabi
What he means is as soon as the computer is switched on, press the F key until something happens, you will know when it does.
Also try tthe ESC key on the top left corner of the keyboard.
Hi everyone;
I have tried tapping F2 for at least 10min. Nothing happened. I pressed Esc as Kee-lo suggested, nothing happened either.
What I don't understant is; if the whole system is crashed,why the window XP gets downloaded everytime I switch on the laptop and why End Task Manager appears whenever I call it up??
Is there any hope to save my laptop?and if there is, what is it???? I paid over 2grand for it and hate to think, it's a waste now
Sabi
Hello, i'm sapnish, i hope you understand my english.
I had one week ago, the same problem.
I switch on and off several times my computer (manually) and the last time, I gave it time to recover, and it was ok, nothing more, I also was afraid, but now it's working perfectly.
I think it needs time to put everything in the memory, give it (switch on) time, five or ten minutes.
If not, switch of, then switch on and press F10 continuously and then select one mode to continuous and just only intro, when it switch on, nothing happens but switch off and then what I said in the other paragraph. It's what I did.
If not, there is a number to phone to microsoft and they have a special number to solve this problem, lot of people have it.
Don't worry it's possible to solve it.
I hope you understand somethig, good luck
