Hi there,
I have had my Sony VAIO laptop (VPCEB4E1E) and so far have had no problems since February. Recently I have been encountering an error message popping up a few times a day, which I will copy and paste the details of at the end so you don't have to read it all now! I have done a full virus scan, repaired the microsoft framework and had no luck with that. Then I attempted to use the assist button and while it started up, as soon as I clicked 'update health status' or one click or contact sony, an error message popped up saying that it had encountered an error and to restart the application!
Any help would be much appreciated, and while it's not affecting the performance of my laptop, I just want the annoying pop up to go away! Thanks in advance, and here are the details of the error:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quitm the application will close immediately.
There was no endpoint listening at net.pipe://localhost/VAIOCare/VCAgent/VCSettingMgr that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerExceptionm if present, for more details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ServiceModel.EndpointNotFoundException: There was no endpoint listening at net.pipe://localhost/VAIOCare/VCAgent/VCSettingMgr that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details. ---> System.IO.PipeException: The pipe endpoint 'net.pipe://localhost/VAIOCare/VCAgent/VCSettingMgr' could not be found on your local machine.
--- End of inner exception stack trace ---
Server stack trace:
at System.ServiceModel.Channels.PipeConnectionInitiator.GetPipeName(Uri uri)
at System.ServiceModel.Channels.NamedPipeConnectionPoolRegistry.NamedPipeConnectionPool.GetPoolKey(EndpointAddress address, Uri via)
at System.ServiceModel.Channels.CommunicationPool`2.TakeConnection(EndpointAddress address, Uri via, TimeSpan timeout, TKey& key)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
at System.ServiceModel.Channels.ServiceChannel.EnsureOpened(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at VCsystray.VCSettingMgrService.IVCSettingMgr.IsEulaAccepted()
at VCsystray.VCSettingMgrService.VCSettingMgrClient.IsEulaAccepted()
at VCsystray.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at VCsystray.Form1.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4961 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
VCsystray
Assembly Version: 6.4.0.14160
Win32 Version: 6.4.0.14160
CodeBase: file:///C:/Program%20Files/Sony/VAIO%20Care/VCsystray.exe
System
Win32 Version: 2.0.50727.4957 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.ServiceModel
Assembly Version: 3.0.0.0
Win32 Version: 3.0.4506.4926 (NetFXw7.030729-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
VCUtility
Assembly Version: 6.4.1.4290
Win32 Version: 6.4.1.04290
CodeBase: file:///C:/Program%20Files/Sony/VAIO%20Care/VCUtility.DLL
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
KeyUtilities
Assembly Version: 6.4.1.5270
Win32 Version: 6.4.1.05270
CodeBase: file:///C:/Program%20Files/Sony/VAIO%20Care/KeyUtilities.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.4926 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
SMDiagnostics
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Runtime.Serialization
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.WorkflowServices
Win32 Version: 3.5.594.4926
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.IdentityModel
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Metrics
Assembly Version: 6.4.0.13280
Win32 Version: 6.4.0.13280
CodeBase: file:///C:/Program%20Files/Sony/VAIO%20Care/Metrics.DLL
System.Transactions
CodeBase: file:///C:/Windows/assembly/GAC_64/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box."
