i thinking of getting ocz memory for my vaio 402 series
i am aware that it has 3200 400 ddr memory installed will any of the ocz 3200 memory mods wrk on this system any help apprech thank u !!!!!!!!
The memory will work on the computer but you wont be able to change the memory timeings as the Advanced Chipset Settings are locked out of the bios normaly by sony.
So you wont be able to overclock the memory using the bios. You might be able to get a software overclocker.
Does any one know about unlocking the BIOS?
You should get a paired set of OCZ memory and replace the memory in the computer, so get 2 x 512Mb chips or 2 x 1Gb chips.
