Hi guys,
I have Pentium 4 2.8 GHz in my Vaio and as far as I know underclocking is not possible, so in this way I want to underclock the GeForce FX 5600 to decrease the graphic chip temperature
Because I'm not a big gamer, so the performance of the graphic card is for me under priority.
Do you guys know some nice (freeware) tools, which I can decrease the rate (MHz) of the graphic card? Like powerstrip.
Is it a good idea to decrease those values? I mean, when I need performnace (i.e. gaming, graphic intensive needs, etc.) I will increase the rate (MHz) back to default.
So, this will save power and decrease the temperature inside.
What do you think ?
cu
Mustang
hey mustang,
i also have a 2,8 ghz without the power... at the moment i am trying to downgrade the processor to 2,2 ghz... we'll see if it works.
i haven't heard of a tool that would work on sony's because "here we go again".... because of block bios settings!!!! yeaihhhh.
i wonder if the whole graphics card can be replaced with a smaller model.....???????????????
Joe
Hi Joe,
hey dude,
there is a tool i just found on the internet called POWERSTRIP... it is used to overclock or underclock graphic cards....
it seems to be working... try it!
Joe
hey folks,
the tools i have tried before didn't work.... becaus of some bios setting that wasn't there!!!!
I have found this tool now on the internet to overclock or underclock the graphicscard to save battery power... it seems to work!!!
POWERSTRIP
Joe
I already mentioned Powerstip. I need a smiliar tool like that
I've found a freeware tool - GeForce Tweak Utility
Under/Overclocking is allowed.
Core Clock (MHz) default: 276
Memory Clock (MHz) default: 552
I'm not a hadrware freak, so which value would be fine for decreasing those rates? What about the relation of the rate between core clock and memory clock?
cu
Mustang
Underclocking should lower the tempretures, but it's not 100% failsafe.
ooooooooooooohhhhhhhhhhhhhhhhh
ok
i have missed something there........
ok
but it works....
Joe
mmmmmmmmmmmmhhhhhhh!!!!!!!!!!!!!!!!!!!
Any other comments?
yohhhhhhhhhhhhhhhhhh
i have tried that gforce tweak tool... it does the same as powerstrip...
but somehow it does not keep the settings
Joe
