I have an FS115Z, and i'm thinking in upgrading his memory from the 2x256Mb Infineon CL2.5 333Mhz to 2x512 (it maximum expanssibilitie) Mushkin CL2.5 400Mhz, do you guys thinks it will work just fine with 400Mhz chips on it, or should I buy 333Mhz chips anyway?
Stay cool.:smileywink:
http://www.cheeep.de/chips.php?name=AGB
Don't forget to read the AGBs! There is no possibility to return the RAM!
If the RAM not works, then you would have bought garbage.
Better to go to Crucial
Yes. By Crucial you have the right to return the RAM if it not works.
http://www.crucial.com/company/termsofsale.asp
Also they have good tech support if you need it.
I've already bought high end RAM in there and I think that theres no trouble in returning the chips if they don't work, but need to see it as the delivery arrives and inform the problem to the shop.
quote:
3. Ein Rückgaberecht nach § 4 Ziffer. 1 besteht insbesondere oder die aufgrund ihrer Beschaffenheit nicht für eine Rücksendung geeignet sind;What I mean is that you could have a lot annoyance, if you read not all.!sad.gif|___jive_emoticon_name=sad|jivemacro=emoticon|class=jive_macro jive_emote|src=sad.gif!
Can you translate it deutch friend? !wink.gif|___jive_emoticon_name=wink|jivemacro=emoticon|class=jive_macro jive_emote|src=wink.gif!
What kind of annoyance?
