I have an FS115Z, and i'm thinking in upgrading his memory from the 2x256Mb Infineon CL2.5 333Mhz to 2x512 (it maximum expanssibilitie) Mushkin CL2.5 400Mhz, do you guys thinks it will work just fine with 400Mhz chips on it, or should I buy 333Mhz chips anyway?
Stay cool.:smileywink:
Thats where the problem starts Rich, the FS series is not listed on Crucial.
You will need 333MHz chips.
They must have added it recently james. FS115
PS love the new signature:smileygrin:
There just happens to be a sales offer on Sony Style for the memory of the FS ( for UK )
seach for : VGP-MM512G
This Memory is extremly overpriced. And there is no reason, to buy this memory.
Yeah Crucial is VERY cheap for memory, I would buy the RAM from them for my machine.
Rich: haha can you tell I was going for the subtle "you wont even know its there" advertising?:smileylaugh:
Lol Big and brash:smileylaugh:
Yeah I have to agree TT - it is vastly overpriced RAM, Crucial and Kingston are both very good (and cheaper!) brands of RAM.
I would NOT recommend getting the Sony RAM from SonyStyle.
So long as you follow the memory installation guide carefully on VAIO-Link then you will be fine.
Precautions:
1. Make sure you are grounded correctly.
2. Do not touch the gold contacts on the memory module.
3. Never force a memory module into a bay - you could damage it that way!
4. Don't touch anything inside the VAIO memory flap.
5. Always replace the cover after installation.
6. Never install RAM in a hot computer. Leave it to cool right down first.
Remember that under the terms of the warranty you aren't allowed to use non-Sony RAM (again, you're being ripped off) so it might be advisable to keep the old RAM around so you can shove it back in should your computer need to go off for repair.
