I have a PCG-GRT916z. It has 2 slots currently occupied with a 256m module in each. Sony state the max system memory is 1g but the Orca site says it can take 2g and they sell 1g modules (guaranteed 100% compatible). Does anyone know if this is correct.
Thanks in advance.
Thanks in advance.
Thanks for the reply. I wasn't sure what the consequences might be and if it's frying everything then I definitely don't want to take that risk. What do I look for on the motherboard?
Hi Hull,
Welcome to Club Vaio,
I've looked on the Orca site and it states the maximum RAM for your GRT916Z is 1GB, see below:
Memory Details for Sony VAIO (Laptop) PCG-GRT916Z
Standard Memory : 512MB (Removable)
Maximum Memory : 1GB
Total Memory Slots : 2
Memory Type : 200-Pin PC2700 (333Mhz) DDR SODIMM
