Hi marakos85 and welcome.
There are no specific Memory Card drivers for Windows 7 for your model.
I would install the THREE MemoryCard drivers originally supplied for Vista - you will find them in the Preinstalled Drivers and Utilities section here: -
http://www.sony.co.uk/support/en/product/VGN-FW31J/updates
As you have done a clean installation of Windows 7, you may also need to reinstall the SFEP driver.
Hi Blencogo, I m grateful for your help, I do this and somehow it's working... thanks a lot
