hello again after being help i installed the garphics card ......but when i start up my pc it shows the pentium and sony bits in a scrabbled like footage but everything else is perfect crsystal clear infact its a sick graphics card but i was woundering if anyone has had the same problem and maybe knows how to sort it out
thanks
ben
It could be that the start up screen is optomised to work with a Nvida card. but as long as windows is running OK i dont think that you will have any problems.
You could look a you BIOS settings to see if you can change the screen on powerup.
