Mini VAIO (file transfer program)refuses to transfer-convert all kinds of files!!
I¿m working with my VAIO VGN-A297xp(win XP pro sp2),
tried to uninstall all programs and devises installed prior to problem start point, and also tried to recover the system rolling back to previous date.
Later I reinstall the VGF-AP1L software (SonicStage2.1+inclouded updates) in Vain.
Please help !
Ps .I also (Hard )reset the player and formatted the disk too .
How about converting to WAV before ATRAC?
Have you tried getting the Microsoft update yet?
Have a look HERE, credit goes to Titane for discovering this link.
Already removed and re-installed SS(if you mean SonicStage)
What is BTW?
Hallo i just have had the same problem, I changed the mp3 in a wave format with an other programm, then i made an atrac out of this one. This works!
Thorin
What is BTW?
It means By The Way.
Thorin
Thorin
Finally I decided to restore my laptop to its factory settings (full recovery).
Since the installation disk of the mini VAIO was left in my office we have to wait till afternoon to see if I succeeded.
Regards, Stelios
Good luck
Good luck
