need to find voltage for a old laptop so i can order a new charger there is no lable and nothing under battery eny help please thanks jen
Hi Jen,
You are quoting the chassis number. Have a look on the lower right hand side of the screen surround for the correct model number – you will probably find it is a VGN-AW21xx.
If this is the case it will be DC output 19.5V, 6.15A, 120W. Model number VGP-AC19V16.
Rich
Hi Jen,
If you let us know the model number of the notebook someone may be able to help.
Rich
Hi jen1749,
welcome to Questions & Answers..:smileyhappy:
You should be able to find the volts & amp information on the underside of your old charger..:smileywink:
If you can not find the information on your old charger let us know your vaio model & we may be able to find the info for you..
i dont have an old charger just the laptop. its an old hand me down,
The vaio model number is - PCG-8141M
product key is -
GMTOQ - JQBQ9 - JGKK9 - JHD8Y - WHWGK
Hi Jen,
Rich
thanks for that the number is vgn-aw21m you can tell i know a lot about computers thanks
You’re welcome Jen:smileyhappy:
hi there i am back needing more info, emailed the charger shop and he saya next to the 19.5 there will be 4.7 or 3.9 thanks jen
Hi Jen,
That will be a universal power adaptor and with an amperage output of either 4.7 or 3.9 it is not suitable for your model.
Did you have a look at the link that Blencogo provided?
Rich
