I m about to install Linux(dont know which one yet) on my vaio pcg-fr315b
Any ideas if it ll work or not?
Your biggest problem will be obtaining suitable drivers, but I've got an HP laptop running it fine. Good Luck!
If anyone wants to try Linux on any laptop the easiest way to check is to run a bootable distribution from cdrom. Google around for Knoppix.
Yes, OSes that fit on a CD and run from a CD are the best ways to find if linux will run well on your computer.
