I've got a special DOS application I'm trying to run on my FR415S - it's a race car data acquisition & analysis package - ancient but works great. unfortunately, it corrupts some of the character set when doing it's graphics - basically, the numbers and some special characters but letters are fine.
the package works fine on Windows 98/ NT and XP systems on other laptops and desktops ( runs in native DOS or emulation on the XP ) - it's just the Vaio that's troubled.
any bright ideas ?
regards
colin
U are using the original configuration?
If so, maybe you can update the videodriver (from ATI) (be sure to use "Systemrestore" so u can go back to a working situation...
Hope this helps...
Regards,
MD
