LCD detached?
Sul
Visitor
LCD detached?
Hi
When I was just observing my LCD recently I noticed that when I view the LCD from a very wide angle - e.g. completely from the side then it looks like the top left of my LCD is slightly detached from the frame so that I can see a bit of light. I look from the other side and it isn't like that there. Should I be worried about this? I don't see any difference in LCD quality of anything like that. I can't think of a cause for this - I always gently clean my LCD so I can't have pushed the LCD off the frame.
1 REPLY 1
profile.country.en_GB.title
kee-lo_
Member
Well, I would be a bit concerned if I was considering taking it on the road.
