Everything went ok with my WinXp Pro, but one: when I shut down (or restart, exactly the same), the notebook logs out, saves data, shutdown mask disappears, and the notebook lasts forever with the blue-XP sceen, the movable muose pointer and nothing more, waiting to power off but never doing it. CTRL-ALT-CANC does absolutely nothing here.
Any idea?
Thank you!
thnx for the quick response, let's hope this is it !
many greetz,
Lester.
Easy now guys
Easy now guys
I know, but it was going a bit too far
I found a patch (http://support.microsoft.com/?id=909667) that solved in my case the Turn Off / Restart problem on XP Pro.
You can download it from here:
http://rapidshare.de/files/11297617/KB909667.exe.html
the patch are avaiable in portuguese?
Thought it was pretty much international
For other languages and to work around this problem, disable the Allow the computer to turn off this device to save power option for all USB Ports in Device Manager.
