Hi there i did this on the old Club Vaio forum, and that was back in April, since then some new Laptops have arrived on the scene.
So below is listed the laptop manufacture then the laptops model number and its result in the 3D Mark 01.
The higher the score the better the laptop performs during 3D work. So a computer with a higher 3D score will be better at things like CAD work, Playing new 3D games like FarCry etc..
Sony
PCG - Z1XSP 1681
VGN - S1XP 10135
PCG - V505DP 5454
PCG - GRT916V 9115
PCG - K215Z 6739
Toshiba
A40 - 892 1757
M30 - 742 6854
M30 - 704 6777
P10 - 803 8906
HP
ZE5169EA 5956
ZX5151EA 7015
ZD7145EA 9957
ZD7050EA 10251
Samsung
V25 - 2.66 975
X05 - 1.4 1839
If you would like to run the 3D Mark on your computer to find out what it will score you can go to the following link and locate a place to download the program from.
www.futuremark.com
There are other benchmark software packages availbule from futuremark like the PC Mark 03 and 3D Mark 03 which i shall post the results of some time soon. These tests need Direct X 9 installed where as 3D Mark 01 utilises Direct X 8.
Another bit of software is Aquamark which i might get round to runing.
Hope this is of intrest to some of you.
Damn thats not a wonderful score.
my VGN-A115Z only got 1131 with 3D MARK 03
It's not:smileycry:
Seems a shame really, as they're good notebooks...
