Hi there
We have got two vaio Destktops in our bureau. A pcv-rs302 and a pcv-rs602. The 2nd one came with a memory card adapter (sd-card to compact flash). But the memory card adapter is only recognised by the first PC.
Can someone help me??:smileycry:
What interface does the adapter use?
The MCA has been shipped with the PC .
It's a little block that looks like a COMPACT FLASH card. And that's where the adapter has to be put in (so it's a ).
Label: "vaio memory card adapter pcga-mca1"compact flash card with a sd/mmc card slot
Oops! Correction:
It's a little block that looks like a COMPACT FLASH card. And that's where the adapter has to be put in (so it's a compact flash card with a sd/mmc card slot ).
thank you for answering
Maybe this card is not compatible with the other VAIO.
The strange thing is that the adapter does only work on the vaio that came without any adapter card.
Is it possible that this adapter only works on the one machine, where it was plugged in for the first time??
Thats very strange
It really should work in them all.
Have you spoke to eSupport?
Maybe I should...
thank you anyway!
Good luck
