Hi there i did this on the old Club Vaio forum, and that was back in April, since then some new Laptops have arrived on the scene.
So below is listed the laptop manufacture then the laptops model number and its result in the 3D Mark 01.
The higher the score the better the laptop performs during 3D work. So a computer with a higher 3D score will be better at things like CAD work, Playing new 3D games like FarCry etc..
Sony
PCG - Z1XSP 1681
VGN - S1XP 10135
PCG - V505DP 5454
PCG - GRT916V 9115
PCG - K215Z 6739
Toshiba
A40 - 892 1757
M30 - 742 6854
M30 - 704 6777
P10 - 803 8906
HP
ZE5169EA 5956
ZX5151EA 7015
ZD7145EA 9957
ZD7050EA 10251
Samsung
V25 - 2.66 975
X05 - 1.4 1839
If you would like to run the 3D Mark on your computer to find out what it will score you can go to the following link and locate a place to download the program from.
www.futuremark.com
There are other benchmark software packages availbule from futuremark like the PC Mark 03 and 3D Mark 03 which i shall post the results of some time soon. These tests need Direct X 9 installed where as 3D Mark 01 utilises Direct X 8.
Another bit of software is Aquamark which i might get round to runing.
Hope this is of intrest to some of you.
Thanks for the info Graham... much appriciated.
How about the A series? Considering one of those myself ...
Realy want to get my mits on one of thoes to, but our buying office down south in there infinate wisdom has decided that only the top 5 branches will get them for display, altough we can order them for sale.
I have tryed my hardest to get my hands on the A115 and the A117.
So if any one out there has one would you mind rinning the tests and posting your results.
Will keep tring to get one up to the branch for us to look and and will give feedback if I can.
Yes they're impressive - I would say probably one of the best looking VAIOs in the time I have been on the board.
Right have run the newer tests and here are the results.
Sony
VGN-S1XP.........3D Mark 03 - 2635.....PC Mark 04 - 3391
PCG-V505DP....3D Mark 03 - 719.......PC Mark 04 - 2828
PCG-Z1XSP.......3D Mark 03 - 77.........PC Mark 04 - 2537
PCG-GRT916V..3D Mark 03 - 1333....PC Mark 04 - 3786
PCG-K215Z........3D Mark 03 - 1063....PC Mark 04 - 3490
Toshiba
A40-892..............3D Mark 03 - 106.......PC Mark 04 - 2521
M30-742.............3D Mark 03 - 1008.....PC Mark 04 - 3210
M30-704.............3D Mark 03 - 704.......PC Mark 04 - 3196
P10-803.............3D Mark 03 - 1852.....PC Mark 04 - 4207
As you can see there is quite a sperad of results here. The VGN-S1XP looks to have the best all round score :smileyapplause:. Where as the PCG-Z1XSP has the poorest scores.
Remember this doesnt necessarly mean that the machine is bad, its just not sutied to this kind of work.
77 is quite low for a 3D Mark test though ?
Yep but that machine has integrated graphics and could only run 1 of the game tests.
Oh I see.
Does the A series have integrated graphics?
Just had a look and they all have a ATI MOBILITY RADEON¿ 9200 and 64 MB VRAM.
This is the same that is in the PCGK215Z but this machine has a P4 so it might have a different outcome depending on a few things such as RAM size and speed and bus speeds.
Put a request in for the A range again so hope to have them soon. Then will get results posted.
Cool
