Hi. I run Windows XP Proffesional SP3, and I am attempting to follow instructions to install a video driver. The instructions come from the Sony website and are these:
1. Download the video driver ( VCD_Nvd_4690.zip ) and save it to a download directory
2. Right-click the Zip file and select Extract All
3. Follow the on-screen instructions to extract the Zip file to a directory (please note this folder for reference)
4. Close all running programs.
5. Open C:\Drivers and rename or delete the "Video" folder
6. Click Start, click Control Panel, and then click the "Add or Remove Programs" icon
7. Select "NVIDIA Windows 2000/XP Display Drivers" and click "Change/Remove"
8. Click Yes, and then Click OK to restart the computer
9. After computer restarts, a Found New Hardware Wizard appears automatically.
However from step 5 onwards none of it is possible. The Drivers/Video/NVidia folder is not there, Nvidia doesnt show up under add or remove programs, and I never have a Found New Hardware Wizard appear. I have checked in device manager and no Video/Display Adapters show under it.
Please help
Hi ItsAaron,
I’m surprised that you can find nothing listed in Device Manager under Display Adaptors or at least an adaptor with a warning that drivers are not installed. If an adaptor of some description was present you could update the driver using the ‘Have Disk’ method:
If all else fails then try installing from the INF file contained within the download package. Extract VCD_Nvd_4690.zip to a known location – such as a new folder on the desktop. Then, within that folder, locate NVSZ.INF, right click and select ‘Install’.
Rich
Hi ItsAaron,
Rich
