Hello!
I make a clean instalation for windows 7 in my SVE1512M1EW windows 8 but now some software is missing and Where can find it??????????????
SM Bus controller
Network controller
Universal serial Bus
and also if possible put back the vaio care and update.
Thanks for help!
Hi moranginho and welcome.
Sony do not support a downgrade to Windows 7 for your model.
Try installeng the 'Preinstalled Drivers and Utilities from a similar model that was sold with Windows 7 installed. You can download the drivers for the SVE1511M1E from here:
http://www.sony.co.uk/support/en/product/SVE1511M1EB/updates
If you install them all, it should fix your problems.
Thanks! now windows 7 is working but still missing parts of vaio
