Hi everyone. I have a new Vaio SVT 1313L1ES laptop. It has Windows 8.
I wish to use my Word installation CD to transfer Word to the laptop, so that I have it there as well as on my PC.
The laptop has no DVD drive. It has an AC outlet, ethernet port, HDMI and USB ports.
I have a DVD player with none of them on it. I think it must be old.It has an AV socket. I presume that I can't use it and need to buy a more up-to-date device.
How would I connect such a device to my laptop in order to install Word from the CD?
And what device should I look for?
Thanks in advance,
Hi blencogo. Thanks for your reply. I'll do just that and buy an external DVD/CD drive, which will in general be useful. Thanks again,
Laurence
Hi DollFin.
You will need a newer external DVD/CD drive which connects to a USB port or Word on a USB Drive.
As this model has no optical drive, an external optical USB drive is a useful accessory.You can create Recovery Discs and you can also boot from an external drive using the ASSIST button.
You can get them for as little as £10 but Blu Ray drives will cost more - try Amazon and search for "External USB DVD Drive"
