Its me again the man with the crashing VP i have had enough and the only way i can see around it is if i format the thing completely as theres no point in having 20G's worth of stuff on it when i cannot even play it.
So how do i get rid of everything on the VP thats including the images updates the lot i want it as it came bran new with nothing on at all.
There is an option to format from the VP, but still you keep the firmware, if I'm not wrong.
To have it just brand new, go to SS with the VP connected to the computer, and use the option Controls - Device/media - Initialize.
you could format you vp and nothing will remain on it but the firmware update you did cannot be erased as it has been written over the files that where in it on the first place...
follow rbn's instructions to format it...
