...well I would like to, but I can't open the tower! I have an RX406 and I want to fit an extra internal hard drive. We have a plan to remove the CD player (as it's rubbish and the DVD player is used all the time!) and put the extra hard drive there, but need to get both side panels off. One side is obviously easy, but can't remove the other one, any suggestions? Thanks.
...sorted ! Thanks to those who viewed and might have been about to reply
