any help would be appreciated... Ive been into it once, but was a lucky mistake... really need to get in and sort out some boot options.
Many thanks
D
ok guys figured it out..... power off then while powered off press the assist key.....
Hi damhall39,
welcome to the Sony user Community forum..:smileyhappy:
Glad you managed to figure it out..:smileythumbsup:
I just got this sorted out on a SVE1513H1ESI as well - realise this doesn't contribute anything to the discussion but - knucklehead that I am - I really need to post a new topic and just can't see where on the forum I do it.
I'm a regular subscriber to a couple of other forums and haven't had this problem before ..............
Can anyone point me in the right direction?
Thanks
Hi Cults14,
In order to start a new topic you will need to enter the sub forums related to your device. Once in there, a blue "New Message" button will appear above the current threads.
Hope this helps.
Regards,
Drew
