Hi all!
Have a VGN-TX1HP, all's working fine following Vista clean install but I'm afraid I don't understand the Hot Key fix. How do you install the driver as an unknown device? In device manager I can't see any way to do this.
Also, not sure if it's related but the audio jack for the headphones isn't working.
Any help much appreciated!
:smileygrin:
Alex
Hi Alex,
welcome to Club Vaio..
Download the Utilities listed below Utilities from Vaio-Link, use the following link: Sony Vaio Support Utilities
Once downloaded extract the files and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..:smileywink:
