I am trying to restore my VGN NR21Z as the S1 and AV buttons are not working.
Is there a simple driver or download which will fix it. If so where can i find it as i'm not having any luck. Is it one of the packages in reinstall software and drivers on laptop? If so which one as when i try to do the lot it errors out.
Paul
Hi Paul,
are you restoring your Vaio using the Vaio recovery utility or are you installing your own copy of Vista.?
The S1 and AV keys are controlled by the Utilities packages, but unfortunately the utilities package for your model does not contain the utilities you require. ie AV Mode Button Utility, Sony Utilities DLL and Setting Utilities Series..
Hi Paul,
I suggest you contact Sony Vaio support and ask them why these utilities are not available, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
Hi Paul,
