I have a VAIO notebook B1XP and i cant enable the Hibernation.. when i check the Enable Hibernation checkbox i get this error..
"The process cannot access the file becouse it is being used by another process." I have XP SP2 and no other app is useing my hibernation file .. in fact the hib file doesnt exist.. does anybody knows a solution or had the similar problem..
Thank you very much
