Hi bit of a computer novice sorry.
got a hdmi cable and my first blu ray dvd now want to watch it through my televsion but just can't seem to make it work any help please???? xxxx
i ave just bought a vgn fz21s on vista
hi there,
well at first of all u should connect ur notebook with ur tv
after u did so, there should pop up a little window that gives u further instructions like in which way u want to enable your view. u can chose between cloning, single view and so on. if u want to play a bd from ur laptop and watch it on the tv, use the single view mode, so that the entire notebook lcd is disabled.
if u dont get such a automatic popup just go to ur nvidia control panel and set it up manualy, another possibility is the mobile center
gl hf
