Hi all
Just done a factory reset on the AR21m after a few problems.
However, the DVD Drive does not work now, when you put a CD in, it makes a few noises as though it is struggling to start, then stops.
When you goto My Computer and look in the DVD Ram Drive icon, it is just blank!
Is this a fault with the drive, if so why should it happen after a factory reset, it worked fine this ,morning??
Any ideas
Lee
Looking at the tracking, it seems to have gone from pickup in Sheffield to Brussells 'Origin Service Area' for about 1/2 a day.
Then back to the 'Destination Service Area' in Leeds the next day, and according to DHL thats where it is now!!
Very Strange, must ask Vaiolink why this is!
Hopefully they managed to change it quickly that day
