Hello,
I want to upgrade my 10Gb HDD to a larger one. I assume it's a 2.5" drive I need.
Is this possible and fairly easy to do on this machine?
Thanks.
Typo - It's a FX301 !
Yep, just take out the old drive and replace with a new 2.5" drive of ur choice. I think Misco sell them.
This guide should be of help to you. It is for a FX190 but the basic architeture of the machine will be the same.
Thanks everyone for the help, I'll give it a go.
Yes, Misco are good - I've bought from them many times.
Cheers.
