Harddrive upgrade FX905P
John_gb
Visitor
I am running out of Harddisk space. Anyone know if there are instructions as to if or how I can replace it with a larger capacity drive?
2 REPLIES 2
flynn
Visitor
Dont know if this applies or is much help, but with many laptops u are able to unscrew the base or unlock a switch on the base or side of the laptop to thus remove the harddrive from the laptop. Technically you should be able to use any compatible 2.5" hard drive to replace it - not necessarily SONY brand. Hope that helps!! ([email protected])
profile.country.en_GB.title
robpaxton
Explorer
I think the newer FX series notebooks are very similar to the older versions; If so then http://www.myplc.com/sony/hard_drive_replacement.htm should help.
