Hi all,my 1st post so be gentle please. Ive just purchased a VGN B1VP laptop off ebay with out a hard drive.The problem i have is tht i can't find a hard drive.Does anybody have any information for me please? I would have thought this was easu but i'm either typing in wrong info or they are like rocking horse s***.Any help would be appreciated.Regards Paul
It is a simple job to fit a new HDD as long as you have the carrier framework that slides into the slot on the outside of your Vaio.
Hi Paul,
Your model was shipped with a Hitachi Travelstar 60GB 2.5” PATA/IDE hard drive.
Any 2.5” IDE drive up to 250GB should work.
Rich
Hi Steady. After you get the hard drive, you need a technician to do this for you since the process will be delicate. You can just go ahead and go to the nearest service center.
Good luck.
Thx every one.I actually found a compatable hard drive in my brother in law's packard bell easynote.I fitted it easily as i have the caddy.I now need to find some cheap memory as it only has 512mb and i want to see if it will run on Windows 7.Is this laptop worth spending money on? Cosmetically it is in good condition,it has a broken hinge and apart from a scratched lid that is it.Thx again
Hi Paul,
You can upgrade to 1536MB by adding a single 1GB module – this is the maximum that this model will support.
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-B1%20Series&Cat=RAM
Whether this is enough to run Win 7 comfortably is debatable. It may be better to stay with Win XP...
Rich
