problem with hard drives,i have two 30gb hard drives on my laptop C & D only C drive has any thing on it, D is empty as my computer is running very slow is there a way of getting both hard drives to run as one.
Hi sparky24,
welcome to Club VAIO..
What model Vaio do you have.?
I suspect that your Vaio has only one 60 GB HDD, which has been partitioned into C & D..
Depending on the disc space occupied by your My Documents folder, a possible quick solution would be to change the default location of your My Documents folder, use the following link to view a guide on the procedure: How to Change the Default Location of the My Documents Folder
Hi sparky24,
welcome to Club VAIO..![]()
