annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
formatting discs
nelski
Visiteur
formatting discs
can someone help? i have pcv-rs224 and need help to format discs as certain ones dont work. example tdk dvdr i can record with but not dvd+rw . also i can only record on phillips cdrs but not others nashua for example. help !!
1 RÉPONSE 1
profile.country.en_GB.title
kee-lo_
Membre
You only need to format RW media if you're going to use packet writing
